The following instructions describe how to perform the replacement of an engine air filter on a fourth-generation Honda Odyssey. The engine air filter collects dirt and debris in order to prevent it from entering the engine and requires replacement after a certain amount of time. Before attempting this task, be sure to allow the vehicle to cool down to avoid getting burned.
Pull out the hood release in the driver's footwell to pop open the hood.
Release the hood latch to lift the hood.
Position hood prop rod into the support hole.
Unlatch the three clips securing the engine air filter cover. (The third clip can't be seen in the photo but is on the other side of the cover.)
Remove the filter by simply pulling it out of the filter compartment.
