This repair guide will show you how to replace the screen on a Fossil Q Marshal Gen 2 smartwatch. Be careful not to damage the wiring or the metal connectors on your smartwatch.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
Remove chain from opposing side of watch body.
Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
Utilize a spudger to pull the orange connector off of the motherboard.
Utilize tweezers to pull the white battery connector from the motherboard.
The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
Taking the flat end of the spudger, pry it up.
The screen can now be removed out of the front-side of the watch.
crwdns2935229:012crwdne2935229:0
crwdns2947412:017crwdne2947412:0
Where can i find a replacement screen for the founder q 2.0 version?
Where can I buy replacement screen for gen 1
Is the screen glued to the bezel of the watch?
Hello,
Do you have spare parts for the Fossil Q Marshal gen 2 watch?
Where can I find a replacement screen for this devise?, I’ve done a little searching but I’m struggling to find someone who sells the replacement parts.
