Forerunner 620 Battery and/or Screen Replacement
  1. Forerunner 620 Battery and/or Screen Replacement, Remove LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Forerunner 620 Battery and/or Screen Replacement, Remove LCD: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the display of the watch by thoroughly heating the display and gently prying with the help of a suction cup.
  2. Forerunner 620 Battery and/or Screen Replacement, Remove the main board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws which secure the main board in place.
  3. Forerunner 620 Battery and/or Screen Replacement, Replace battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Forerunner 620 Battery and/or Screen Replacement, Replace battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Forerunner 620 Battery and/or Screen Replacement, Replace battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the connector for the battery breaks, you can solder the connections directly to the motherboard.
    • If the connector is still intact, you can simply clip the new one into place.
  4. Forerunner 620 Battery and/or Screen Replacement, Replace the LCD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the LCD is broken, you can replace it by removing the two flat cables which connect it to the main board.
    • The touch screen cable has a lock with a small white lever which should be lifted gently to remove the cable.
  5. Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can now glue the display back in place using B-7000 adhesive.
phico
crwdns2935283:003/22/21crwdne2935283:0
295 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
Where did you find the replacement battery?
Clarence Chung - crwdns2934203:0crwdne2934203:0
I bought this model on Amazon : "
CELLONIC® Smartwatch Replacement Battery PD3032, 361-00047-0 Compatible with Garmin Approach S1, Forerunner 110, Forerunner 210, Forerunner 610, Forerunner S1 Replacement Battery 200 mAh Battery Fitness Tracker
Philippe Collignon -
Do you have the dimensions of the original battery?
Is B7000 adhesive necessary?... or will E6000 also work the same?
Thanks in advance.
jjc - crwdns2934203:0crwdne2934203:0
Changed the battery, all good, except that the touch screen is no longer responding to my touch. :<
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 3,707
