FoodSaver V4980 Drip Tray Drawer Replacement
  1. FoodSaver V4980 Drip Tray Drawer Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FoodSaver V4980 Drip Tray Drawer Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the PH2 screwdriver to remove the three 14mm Phillips Head screws.
    • Use a plastic opening tool to remove the rubber toppers, covering four more 14mm Phillips Head screws, and remove those screws with the same screwdriver.
  2. FoodSaver V4980 Drip Tray Drawer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You may now carefully unhinge the bottom panel.
    • The bottom panel does not completely come off. There are many wires connecting the panel to the body of the machine, so be careful not to remove any of them on accident.
    My unit wasn't vacuuming the bags properly. I followed your instructions and found a vacuum line pinched closed. I repositioned it and the unit works great. Thanks for posting this. It saved me from having to buy a new unit.
    matt.doran228 - crwdns2934203:0crwdne2934203:0
  3. FoodSaver V4980 Drip Tray Drawer Replacement, Drip Tray Drawer: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The drip tray should come right off. You may clean this afterwards and/or replace it, whichever is needed most.
    My wife pulled the drip tray drawer outward to clean. It will not go back in. I’ve taken it apart, and it would appear that to drawer James against the long oval shaped rubber sealer? Won’t close.
    Charlie Scullion - crwdns2934203:0crwdne2934203:0
Mackenzie Grossgold
crwdns2935283:004/14/16crwdne2935283:0
940 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 34-17, Maness Spring 2016 crwdns2935289:0Cal Poly, Team 34-17, Maness Spring 2016crwdne2935289:0
CPSU-MANESS-S16S34G17
crwdns2947412:09crwdne2947412:0
I don’t need to replace the tray. I’m just trying to open it so I can clean it out. How can I open it? I pulled on the 2 tabs on the bottom and tried opening it but the tray will not open.
Jerry - crwdns2934203:0crwdne2934203:0
You shouldn’t be pulling on any tabs. With the machine right side up there is a recess in the middle at the bottom that you can hook your fingers in. Then you can pull it out like a drawer.
scottthomas -
Same problem here. I followed the above directions and still I can not access the tray for cleaning.
Jeanniehow - crwdns2934203:0crwdne2934203:0
This is the same procedure for the V4825 model in case anyone has that one.
scottthomas - crwdns2934203:0crwdne2934203:0
You can completely remove the tray, but a couple additional steps are needed.
You need to slide the circuit board out. There is sufficient space to do so and it isn't fastened in place with screws or clips. You may need to clip the zip tie holding the wires and vacuum tubes to do so.
Once it is out, you can remove the 3 pin connector going to the tray sensor contacts. From there, remove the cable and the tray can finish sliding out for cleaning. It also gives better access for cleaning the top half of the vacuum chamber.
Reinstallation is opposite of removal. Make sure the sensor cable isn't getting pinched or bunched up when sliding the tray in/out before screwing the bottom back on.
Mark Dietz - crwdns2934203:0crwdne2934203:0
When we pulled the sealing tray out to clean it like we usually do it would not go back in. We are at a loss as to what can be causing this. We have taken the bottom off and still cannot determine the issue. We are both pretty handy so this is frustrating. Model V4445.
Bev Dixon - crwdns2934203:0crwdne2934203:0
I have just experienced this same problem. Owned this for years, and have never had a problem…. Now, after cleaning the tray, it won’t slide back in and I can’t understand why. I’ve looked and don’t see anything in the way…. Any thoughts? Don’t want to throw out a machine that isn’t broken…
Roxanna Horton -
Hi, I need a FoodSaver V4880 Drip Tray Drawer Replacement. Do you know where I can get one?
Rick - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,293
