crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓If your Flydigi Apex 5 controller fails to turn on or loses power sooner than expected, the cause may be a failing battery. Batteries fail overtime as they are repeatedly charged and discharged from use. Follow this guide to replace the battery.
Before starting, consult the Flydigi Apex 5 Not Charging troubleshooting page to confirm that the battery is your controller's issue.
Warning: Lithium-Ion batteries can be a fire hazard. If the controller battery appears swollen, follow iFixit's guide on What to do with a swollen battery.
Spudger4.9
Precision Dispensing Bottlescrwdns2942747:0crwdne2942747:0
Orient the controller so that its back is facing you.
Apply firm downward pressure to remove both the M3 and M4 back paddles.
Turn the controller over so its front faces you.
Remove the D-pad by firmly pulling it away from the body of the controller.
Remove the clear, magnetically-adhered faceplate of the controller by firmly pulling it away from the body of the controller starting from the edge of the faceplate.
Remove the small cover from the rear of the controller by pushing it upward.
Remove the two 5.8mm screws behind the battery cover using a Phillips #0 screwdriver.
Remove the six 10mm long screws from the front of the controller using a Torx T6 screwdriver.
Insert the plastic opening tool between the top and bottom plastic controller molds, then pry until the two pieces separate.
Carefully remove the back paddle ribbon cable with the angled tweezers or spudger.
Press a prong of each side of the angled tweezers under the lip of the power supply cable connector and pull the plastic connector out of its terminal.
Pull the power supply cable through the plastic cable guides.
Pry up the battery with the plastic hook and pry tool.
