The Fluance RT83 turntable is belt driven. This means that the motor that spins your records is attached to your turntable's platter by a belt.
The rubber belt on a Fluance turntable plays an essential role in preventing the platter which the record lays on from receiving any vibration produced by the motor.
If your turntable is having difficulty playing at your desired speed, or playing at all, it's likely time to replace your turntable's belt.
I will be using a Fluance RT83 for this guide, however, the guide will be applicable to Fluance's RT82, 83, 84, and 85 models.
Follow these simple steps to replace the belt on your Fluance turntable.
Lock the tonearm in place with the tonearm clip.
Lift the rubber mat and place it to the side.
Unhook the drive belt from the motor pulley.
Remove the drive belt from the metal platter.
Grab the new drive belt.
Wrap the new drive belt around the motor pulley.
Once your drive belt is hooked around the motor pulley, continue wrapping the drive belt around the entire metal platter.
Make sure your drive belt is flush against the platter.
Give your metal platter a gentle spin clockwise.
When spinning, the platter should continue to spin for a few seconds on its own.
Place the rubber mat back on top of the metal tray platter.
Test by playing a record.
