Floor Pump Gauge Replacement
  1. Floor Pump Gauge Replacement, Removing the Gauge Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Floor Pump Gauge Replacement, Removing the Gauge Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a flat head screwdriver, pry up an edge of the gauge cover.
    • Remove the gauge cover.
  2. Floor Pump Gauge Replacement, Removing the Gauge Face Plate and Internals: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Floor Pump Gauge Replacement, Removing the Gauge Face Plate and Internals: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Floor Pump Gauge Replacement, Removing the Gauge Face Plate and Internals: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • No parts from the old gauge will be re-used, so there is no need to attempt to preserve the parts. However, be careful not to damage the gauge housing.
    • Pry up a corner of the gauge face plate.
    • Use pliers to pull off the gauge face plate.
    • Be careful not to cut yourself when prying off the face plate, as the edges are sharp.
    • Use pliers to pry out the internal gauge mechanics.
  3. Floor Pump Gauge Replacement, Removing the Old Gauge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Floor Pump Gauge Replacement, Removing the Old Gauge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using pliers, grip the exposed brass piece and unthread the gauge by rotating it counter-clockwise.
    • Pull the gauge out of its housing.
  4. Floor Pump Gauge Replacement, Replacing the Gauge O-rings: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Floor Pump Gauge Replacement, Replacing the Gauge O-rings: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the O-ring at the bottom of the threaded hole.
    • Place a new O-ring into the hole.
  5. Floor Pump Gauge Replacement, Applying Threadlocker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply medium-strength Loctite (green, 290) to the threads on the new gauge.
    • Apply a thin layer, but make sure it covers all the threads.
  6. Floor Pump Gauge Replacement, Installing the New Gauge: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Floor Pump Gauge Replacement, Installing the New Gauge: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Floor Pump Gauge Replacement, Installing the New Gauge: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thread the new gauge into the floor pump by turning it clockwise in its housing.
    • Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
    • Gauge performance will not be affected by its position, so long as it is snug.
    • Allow at least 30 minutes for the thread locker to set.
    • Test the pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0635crwdne2935297:0
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 3,068
