This guide will walk you through how to remove and replace the circuit board should your device be broken or malfunctioning. You will need a # 1 Phillips Head screwdriver, a plastic opening tool and tweezers. This easy process should take no more than 15 minutes.
Unlock the battery cover by sliding the switch to the unlock position.
Remove the battery cover by sliding it down the camera.
Slide the black upper casing off from the device.
Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
Remove the top casing from the bottom to reveal the inner circuit board.
Remove the six 1mm screws with the 1 Phillips head screwdriver.
Gently separate the circuit board from the casing.
Unscrew the single 1mm screw from USB housing unit.
Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
Gently pry out the USB housing unit with the Ifxit Opening Tool.
Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
Unscrew the camera housing unit from the plastic case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
With tweezers, remove the microphone and USB connections.
Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
Remove the single 2.1 mm screw and separate camera from the circuit board.
