Flip Video Directional button replacement or cleaning
  1. Flip Video Directional button replacement or cleaning, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flip Video Directional button replacement or cleaning, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Flip Video Directional button replacement or cleaning: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Flip Video Directional button replacement or cleaning: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flip Video Directional button replacement or cleaning: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Flip Video Directional button replacement or cleaning: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Flip Video Directional button replacement or cleaning: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Flip Video Directional button replacement or cleaning, Flip Video Directional button replacement or cleaning: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silicone directional pad insert from the front outer shell.
    • Clean the buttons with soapy water before reassembling the device.
    • Make sure it is completely dry before placing back into the device.
Elizabeth
crwdns2935283:004/15/10crwdne2935283:0
100 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 26-21, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 26-21, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S26G21
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,057
