Flashforge 5M Cold Pull Maintenance
crwdns2869540:0crwdne2869540:0: 88
15
88
88
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:03crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
Adventurer 5M Cold Pull Procedure to help clean the nozzle without removal of the nozzle
    1. Flashforge 5M Cold Pull Maintenance, Heat up the nozzle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Start by cutting and removing any current filament that is loaded inside the nozzle. Then heat the nozzle by pressing the nozzle temperature icon, a popup should appear asking you how hot you would like the nozzle. Heat up to 230 degrees or higher.
      • The heat bed does not need to be heat up.
    2. Flashforge 5M Cold Pull Maintenance, Remove the PTFE Tube: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Removing the PTFE tube is simply pulling it off.
    3. Flashforge 5M Cold Pull Maintenance, Cleaning the nozzle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Grab unused filament and slowly push it down the nozzle.
      • Once you think you have pushed far enough(Ideally untill filament starts to ooze out of the nozzle) yank it out with a swift movement to grab any dust
      • Do this as many times as desired(5-7 times is ideal, but for more thorough cleaning, 9-12 or more is needed)
    4. Flashforge 5M Cold Pull Maintenance: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Put back the PTFE tube, and done.
When done, always make sure you set the nozzle temperature back to 0.
Wyatt
crwdns2935283:009/18/25crwdne2935283:0
175 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 88
crwdns2959996:0crwdne2959996:0 88
