Flash Motherboard
  1. Flash Motherboard, Front and Back Covers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Flash Motherboard, Front and Back Covers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Flash Motherboard, Front and Back Covers: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Flash Motherboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Flash Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Flash Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Flash Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Flash Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The camera should look like this once the front cover is removed.
  6. Flash Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Flash Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Flash Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Flash Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. Flash Motherboard, Flash Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn to the front of the camera.
    • Find the flash motherboard located behind the flash assembly on the top right.
  9. Flash Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron and a desoldering wick to disconnect the wires from the marked locations.
    • Once the cables are disconnected, you are now ready to install a new motherboard.
Jakub
crwdns2935283:004/19/11crwdne2935283:0
134 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-6, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 8-6, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S8G6
crwdns2935297:022crwdne2935297:0
crwdns2942667:0crwdne2942667:0 4,009
