Fixing the Error Code 165-6596
  1. Fixing the Error Code 165-6596, Removing the stylus and battery lid: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fixing the Error Code 165-6596, Removing the stylus and battery lid: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the stylus. This in order to correctly remove the back cover
    • Unscrew the battery lid with the P00 Philps Screwdriver.
  2. Fixing the Error Code 165-6596, Removing the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the lid, carefully remove the cable connecting the battery to the motherboard and lift up the battery
  3. Fixing the Error Code 165-6596, Removing the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw covers with the pick and use the Tri-wing Screwdriver to unscrew the remaining screws around the GamePad.
    • Lift up the back cover
    • Lift up gently, as the rumble motor is attached
  4. Fixing the Error Code 165-6596, Reseating the NFC board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I have put a circle around the correct placement of the NFC board. This is how it should look like.
    • If the NFC board is detached, gently reseat it back to where it was.
    • If the NFC board seated correctly, gently remove and gently reseat it.
To reassemble your device, follow these instructions from Step 3 in reverse order. If the problem persists (even after multiple attempts), it might be time to order a replacement part.
ChrisLord9
crwdns2935283:001/06/23crwdne2935283:0
307 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 80
crwdns2942667:0crwdne2942667:0 2,434
