Fixing a bad output jack in a Fender Stratocaster
  1. Fixing a bad output jack in a Fender Stratocaster, Gather tools: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gather your tools, all we'll need for this is the guitar and an appropriately sized socket driver. Later on we may need a phillips head screwdriver so it would be good to have one just in case.
  2. Fixing a bad output jack in a Fender Stratocaster, Locate the Output Jack: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For beginners, this is where you plug your guitar cable in from your amplifier
    • Inspect the threaded hex bolt, called a jam nut, within the socket. If it's loose, it will need to be tightened. A poorly fitted cable is the most common cause of any feedback you may experience when playing.
    • Another way to test the tightness of the jam nut is to insert your cable into the the jack and see if it's loose. Any movement while the cable is inserted can cause amp feedback.
  3. Fixing a bad output jack in a Fender Stratocaster, Tight the Jam Nut: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert hex driver around the jam nut. Be wary of scratching the surrounding output jack, it can be a tight fit.
    • Give the jam nut a few turns until it starts to tighten.
    • Be sure to not overtighten it, doing so has the potential to sever the connection wires underneath.
    • When you've tightened the jam nut, test your guitar by inserting the cable and turning on the amp. If the feedback remains, continue this tutorial for more troubleshooting. If it's fixed, play your favorite tune!
  4. Fixing a bad output jack in a Fender Stratocaster, Opening the jack: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fixing a bad output jack in a Fender Stratocaster, Opening the jack: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fixing a bad output jack in a Fender Stratocaster, Opening the jack: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the feedback issue remains, we'll need to open the output jack. Start by removing the two phillips head screws located on top and bottom of the plate.
    • Carefully lift the jack from the body of the guitar. Don't pull too hard, some guitars don't have very long wire leads at this connection.
  5. Fixing a bad output jack in a Fender Stratocaster: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect the two soldered wires and the jack connection point. The connections should be strong and free of any corrosion.
  6. Fixing a bad output jack in a Fender Stratocaster: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before screwing the plate back down, it's a good idea to check the jack's contact.
    • Take a guitar amp cord that IS NOT plugged in to an amp and insert it into the jack area. Make sure the contact is touching the end of the cord's tip as pictured.
    • If everything looks good, screw the plate back down and test the guitar. If the issue persists, a replacement jack may be needed.
Ryan Field
crwdns2935283:003/19/16crwdne2935283:0
160 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 115
crwdns2942667:0crwdne2942667:0 4,039
