Fix strobing Aerogarden Ultra LED lights
  1. Fix strobing Aerogarden Ultra LED lights, Disconnect hood from Aerogarden: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the instructions to disconnect the hood from the Aerogarden:
    • Unplug the power cable from the hood
    • Pull out the tab on the back of the hood
    • Lift the hood off of the post
    If your model doesn't have a tab, you can try turning the head to the left or right and lifting up.
    Nick Franklin - crwdns2934203:0crwdne2934203:0
  2. Fix strobing Aerogarden Ultra LED lights, Remove screws from hood: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all screws using philips head screwdriver
  3. Fix strobing Aerogarden Ultra LED lights, Remove clear plastic light cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix strobing Aerogarden Ultra LED lights, Remove clear plastic light cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry clear plastic light cover out of two clips on one long side of the hood.
    • Slide plastic cover out of other two clips, being careful not to lose the clear plastic screw retainers at the corners.
  4. Fix strobing Aerogarden Ultra LED lights, Remove LED light panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix strobing Aerogarden Ultra LED lights, Remove LED light panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Similar to last step, gently pry LED panel out from the plastic clips in the hood. Note that the clips have two slots, one for the LED panel and one for the cover. You will need to get past both of them.
    • The wires for the LED panel will be attached, so rather than setting it aside, flip it over to expose the power board.
  5. Fix strobing Aerogarden Ultra LED lights, Remove insulating sheet: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix strobing Aerogarden Ultra LED lights, Remove insulating sheet: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four screws in the power board.
    • Remove the white plastic sheet and set it aside
  6. Fix strobing Aerogarden Ultra LED lights, Prepare heat sink for removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix strobing Aerogarden Ultra LED lights, Prepare heat sink for removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix strobing Aerogarden Ultra LED lights, Prepare heat sink for removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove power board from hood and flip over
    • Remove bolt from heat sink. Note that there is a nut under the heat sink, so you will need to hold the nut with your finger while unscrewing the bolt.
    • Use knife to separate adhesive from heat sink. There is white adhesive under the heat sink that will hold it in place. Being careful not to cut anything else, slide a knife between the heat sink and the adhesive to separate the two. You may need to do this on all sides of the heat sink. There is no need to remove the adhesive.
  7. Fix strobing Aerogarden Ultra LED lights, Remove heat sink: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The heat sink is attached by 2 solder joints. Desolder these.
    • Carefully remove heat sink.
  8. Fix strobing Aerogarden Ultra LED lights, Remove capacitors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix strobing Aerogarden Ultra LED lights, Remove capacitors: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note the orientation of the capacitors. The stripes on the sides indicate the polarity and will all face the same direction. You will need to orient the new capacitors the same way.
    • Desolder the 3 cylindrical capacitors. Some are directly soldered to other components, so the joints will be larger and cover multiple leads. There is no need to desolder the other components.
    • Remove the capacitors from the board.
  9. Fix strobing Aerogarden Ultra LED lights, Add replacement capacitors: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix strobing Aerogarden Ultra LED lights, Add replacement capacitors: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Bend the new capacitor leads at a ninety-degree angle in the direction matching the picture. This will orient them correctly and allow them to fit under the heat sink.
    • Thread capacitor leads through the holes where old capacitors were.
    • Double-check that the capacitor stripes face the same way as noted in step 8.
    • Solder the new capacitors in place. Some joints may bridge multiple leads as before.
    • Trim the excess leads with wire snips.
  10. Fix strobing Aerogarden Ultra LED lights, Reattach heat sink: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix strobing Aerogarden Ultra LED lights, Reattach heat sink: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix strobing Aerogarden Ultra LED lights, Reattach heat sink: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put the heat sink back in place, making sure to orient it so the bolt will go through the component as before.
    • Attach the heat sink by adding solder to the two heat sink pins sticking through board.
    • Screw the bolt through heat sink and component and into nut as it was originally.
To reassemble your device, follow steps 1-5 in reverse order.
Scigrapher
crwdns2935283:010/14/22crwdne2935283:0
365 crwdns2915208:0crwdne2915208:0
crwdns2947412:018crwdne2947412:0
Worked perfectly. Great instructions and fixed the blinking problem! Thanks!
Jason Bjur - crwdns2934203:0crwdne2934203:0
I'm glad it worked for you. My Aerogarden continues to work successfully and I hope yours does too!
Scigrapher - crwdns2934203:0crwdne2934203:0
This worked like a charm. My Ultra LED is working good as new. Great, easy to follow nstructions and the capacitors are cheap and easily found on Amazon. Thank you!
Steve Rhoden - crwdns2934203:0crwdne2934203:0
Thank you so much. I was able to repair my Aerogarden because of this article. I appreciate that you shared the information!
J Taylor - crwdns2934203:0crwdne2934203:0
Suggest everyone to first open their unit to confirm identical model prior to ordering capacitors. Mine appeared identical from the outside, but once opened up, the electronics were completely different. Must be an older (or newer) version.
Karl Evans - crwdns2934203:0crwdne2934203:0
I followed your instructions and when I plugged it back in the lights aren’t coming on. I can hear that the pump is working through. Any suggestions on what I did wrong and how to fix it?
Terri Burkard - crwdns2934203:0crwdne2934203:0
The only suggestion I have is that the soldering went wrong. If you have a multimeter, I'd check to make sure that all of the components are soldered in correctly by checking the continuity of the circuit. I'd also check to make sure that the solder hasn't short-circuited anything by connecting pins/components that aren't meant to be connected.
Scigrapher -
You’re probably right. This was my first attempt at soldering anything. Do you mind emailing me? Trsheltn@gmail.com
What about? I have to tell you that I'm not an experienced solderer, nor electrician, so I'm not going to be able to give you much advice.
Scigrapher -
You definitely have more experience than me. I was going to see if you’d be open to me shipping it to you to try and fix it. I tried to find a replacement hood and can’t find one anywhere. Seems silly to have to buy a whole new unit. I’d pay you, of course.
Soldering is a skill but an easy one to be effective.
For a project this fine get the smallest ROSIN CORE solder you can find.
One tip is to "tin" the tip of the iron first.
Let the Iron get hot 1st then melt some solder on it, then wipe it off on a heavy cloth.
If the solder "beads up, repeat. If it sticks to the iron you are good to go.
Touch the tip to the object (capacitor lead) to heat the wire 1st.
It also helps if you have a tiny bit of molten solder on the tip to transfer the heat.
You don't need to heat the board as the foil traces are extremely thin and the hot solder should bond quickly. Too much heat can easily damage the board.
Let the hot solder on the lead flow onto the board and be careful not to let it move while you are working.
The finished solder joint should appear shiny and not craggy. If it IS craggy, reheat it.
Good Luck and I hope fixing it yourself is as satisfying to you as it is to ME!
Ralph0 -
THANK YOU SO MUCH FOR THIS!!!!
Aerogrow is closing shop. I ordered a new pump and light last month. 2 weeks ago mine began to flash.
I was so happy to find I could repair this one so easily. I got 6 Caps so I can do it again if needed.
The hardest part was replacing the heat sink screw. I struggled for a while but didn't think it wise to screw it onto the sink before soldering the sink to the PC board. I eventually out the screw on a narrow piece of scotch tape to give me a "handle to align it.
Thanks Again!!!!!
Ralph0 - crwdns2934203:0crwdne2934203:0
Funcionó perfecto! Una segunda vida para mi Aerogarden Ultra. Gracias!!
C Gongora - crwdns2934203:0crwdne2934203:0
Brilliant writeup, can't thank you enough!!
Steve Cabito - crwdns2934203:0crwdne2934203:0
Any suggestions where to start on a farm xl for strobing lights? Everything else works as it should. I was hoping when I opened it up it might have the same set up for the lights but it didnt.
Ashleigh - crwdns2934203:0crwdne2934203:0
Unfortunately, no... I've never even seen a farm XL. When you say you "opened it up", did you look in every part of the device? I'd expect that there's still somewhere in there with capacitors on a circuit board. Looking at the Farm 12XL on the Aerogarden site, I'd think that the light or the top part might be where you need to look. That's 100% speculation, though.
The lights get plugged into the hood. The hood is where the circuit boards are. I do see some different capacitors looking things but none are bulging, I looked at the joins for cracks and didn't see anything out of the way. My problem is I wouldn't know which ones would be for the lights. It worked fine lights went off for the night and got the flicker the next morning. I took a photo of the inside but don't see a way to post it.
Ashleigh -
Unfortunately, I don't think I can help you. I can tell you that capacitors can fail without giving visible evidence that they're no longer working. If that's the problem, the only way to tell would be with a multimeter that supports capacitance testing. Even saying that, I can't guarantee that's the problem, especially since the device is so different.
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 226
crwdns2942667:0crwdne2942667:0 8,384
