Fix for Vanmoof S2 Not Charging
  1. Fix for Vanmoof S2 Not Charging, Bike not charging when plugged in: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Under normal conditions, when plugged in and not fully charged, the light on the charger should turn red.
    • If it stays green (as shown) even while the bike itself indicates charging, the solution below will probably work for you.
    • Vanmoof has a great video on how to remove the smart cartridge. You will need to buy the necessary Torx wrench because I don't think it comes with the bike.
  2. Fix for Vanmoof S2 Not Charging, Open up the smart cartridge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the screws from the circled plate
    • Pull apart that half of the smart cartridge. There is adhesive near the charging port so it may be a bit tough to pull apart at that end.
  3. Fix for Vanmoof S2 Not Charging, Confirm the connector has arced: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The pictured connector should look burnt in some way. It's possible that some end up completely melted.
    • Cut the plastic off the wires and then strip them so that they can be soldered to the pins
  4. Fix for Vanmoof S2 Not Charging, Solder the wires: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder the wires to the pins where the connector used to go
    • Reassemble everything and the bike should now charge.
crwdns2935229:019crwdne2935229:0
Coleman Oei
crwdns2935283:007/08/22crwdne2935283:0
847 crwdns2915208:0crwdne2915208:0
crwdns2947412:034crwdne2947412:0
Thank you. I'm not very skilled with such things, but it worked out pretty good and I didn't find it to complicated.
Marcel M - crwdns2934203:0crwdne2934203:0
sure np I didn't think it was "difficult" either but the description of difficult said something like "requires soldering" so I put it as difficult 🤷‍♂️
Coleman Oei -
Fiddly but not complex. I was using a soldering iron for the first time and just about managed it. Thanks for the post.
Three Sea Shells - crwdns2934203:0crwdne2934203:0
Hi, I have same problem, I think there is a problem with the bms ! Any idea how can I fix it ?
Kreont i - crwdns2934203:0crwdne2934203:0
sorry. dont know much besides what I wrote above. If you have more details I might be able to help. There is also a vanmoof subreddit that has been able to instruct me on how to fix a lot of the issues ive had with the bike so you might try that.
Coleman Oei -
crwdns2936753:07crwdne2936753:0 58
crwdns2936753:030crwdne2936753:0 217
crwdns2942667:0crwdne2942667:0 21,513
