Fix NUC8i7BEH overheating
  1. Fix NUC8i7BEH overheating, Turn NUC upside down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Turn NUC upside down: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Turn NUC upside down: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the NUC upside down and select a PH2 Phillips screw driver bit
  2. Fix NUC8i7BEH overheating, Unscrew lower lid: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix NUC8i7BEH overheating, Unscrew lower lid: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by using a Phillips head #2 screw driver to remove the lower screws on the lower case door.
    • These screws are held in with retainers, so they won't fall out when you flip the lid.
  3. Fix NUC8i7BEH overheating, Lid and HDD Bracket: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Lid and HDD Bracket: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Lid and HDD Bracket: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the door, and keep an eye on the cables that connect to the NUC's motherboard. These cables are the power and data cables for the 2.5" hard drive bay.
    • Carefully unplug the cables from the motherboard, and set the bracket aside.
    • In the last photo, the slot for a blade SSD is marked with a red arrow. This is where you would install the blade SSD, and use a screw to hold it in place.
  4. Fix NUC8i7BEH overheating, SSD removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix NUC8i7BEH overheating, SSD removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Change the screw driver bit to the PH1 one.
    • Unscrew the V-NAND SSD and carefully slide it out of its connector.
    • Previous step as video
  5. Fix NUC8i7BEH overheating, Motherboard Removal (Screw driver): crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Change the screw driver bit to PH1
  6. Fix NUC8i7BEH overheating, Motherboard Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Motherboard Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Motherboard Removal: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the screws marked in red circles
  7. Fix NUC8i7BEH overheating, Motherboard Removal, continued.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Motherboard Removal, continued.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Motherboard Removal, continued.: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the WiFi and Bluetooth antenna cables (be extremely careful when doing this otherwise you risk to rip the base contact terminal off the PCB)
    • Remove the stereo mic cable from the motherboard connector.
    • Pay attetion to the WiFi cable hidden under a black piece of tape
    • Disconnect mic cable
    • Remove padders from the sides
  8. Fix NUC8i7BEH overheating, Remove protection padding, continued: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix NUC8i7BEH overheating, Remove protection padding, continued: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Not all are necessary only the two depicted.
  9. Fix NUC8i7BEH overheating, Motherboard Removal, final step: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Motherboard Removal, final step: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Motherboard Removal, final step: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pry tool to lift the motherboard from the casing
    • Marked with red circles the dust signs evident on first sight
  10. Fix NUC8i7BEH overheating, Remove CPU fan: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Remove CPU fan: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Remove CPU fan: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 screws fixing the CPU fan
    • Remove the fan power connect from the motherboard
  11. Fix NUC8i7BEH overheating, Blast off dust from CPU air exit fins: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Blast off dust from CPU air exit fins: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Blast off dust from CPU air exit fins: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will need to use compressed air, a small vacuum cleaner or something similar to blast off all the stucked dust.
  12. Fix NUC8i7BEH overheating, Blast off dust from CPU air exit fins, continued: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I'm using a compressed air can (optional)
    • Video of the procedure
  13. Fix NUC8i7BEH overheating, Exchange thermal paste for CPU cooler (optional): crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix NUC8i7BEH overheating, Exchange thermal paste for CPU cooler (optional): crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This step is probably not necessary, but for the sake of completeness here it is.
    • Remove the screws holding the CPU cooler following the numbers on them.
  14. Fix NUC8i7BEH overheating, Clean old CPU thermal paste: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Clean old CPU thermal paste: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fix NUC8i7BEH overheating, Clean old CPU thermal paste: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use isopropyl alcohol for this, be careful not to touch the the thermal pads on the chips around the CPU.
  15. Fix NUC8i7BEH overheating, Reapply CPU thermal paste: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful not to apply too much of it.
crwdns2935229:044crwdne2935229:0
Vladimir Knobel
crwdns2935283:003/27/14crwdne2935283:0
3 056 crwdns2915208:0crwdne2915208:0
crwdns2947412:031crwdne2947412:0
Great tutorial, thanks, now my fan is very clean and quiet. Thanks for spending time to create this guide!
Schüszterl Ferenc - crwdns2934203:0crwdne2934203:0
I did see this guide after finding out the same steps myself and having seen this guide before doing so would be very helpful.
Jack Graus - crwdns2934203:0crwdne2934203:0
Great tutorial. Clear pictures, solid instructions. Thanks a lot!
Koen Veys - crwdns2934203:0crwdne2934203:0
you are welcome
Vladimir Knobel -
crwdns2936751:024crwdne2936751:0 27
crwdns2936753:07crwdne2936753:0 161
crwdns2936753:030crwdne2936753:0 681
crwdns2942667:0crwdne2942667:0 56,200
