Fix LG 32LF360V clouding
crwdns2869540:0crwdne2869540:0: 2.1K
2
19
87
2,082
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:030crwdne2931287:0 - crwdns2931291:02crwdne2931291:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
This guide shows how to fix the clouding effect (bright spots on the display).
      • Lay the TV face down on a table so that the stand is not touching the table and the TV is level.
      • It is best to place a soft cloth under the display so that it cannot be scratched.
      • Unscrew the two Phillips screws from the base and pull it down so that it can be loosened.
      • Unscrew the six Phillips screws from the back cover.
      • The one screw between the connectors has a different shape than the others, keep it separate from the others.
      • Now slide a pick between the back cover and the frame and gradually separate them until all sides are loose.
      • The upper side can take a lot of force, if it doesn't work with a pick, try to open the back cover as far as possible until the upper side detaches itself.
      • Take the IR receiver out of its place and disconnect the cable from the mainboard.
      • The cable can break quickly, disconnect it carefully.
      • Take the speakers out of their place and disconnect the cables.
      • Unscrew the 8 Phillips screws from the two metal covers on the bottom of the TV.
      • Now fold up the two black brackets on the boards you just uncovered and take out the flex cables.
      • The brown flex cables at the bottom of the boards are very sensitive. If these are damaged, the entire display may no longer work.
      • Unscrew the 18 Phillips screws on the sides of the TV.
      • Turn the TV over.
      • Carefully remove the frame around the display.
      • Before you start: the LCD display is highly sensitive and can break at the slightest bend. Be as careful as possible with this step and give yourself enough time.
      • Use several suction cups to remove the LCD display from the frame.
      • Again, you have to be careful with the brown flex cables just mentioned, as they come out with the display in this step.
      • Remove the 2nd frame with e.g. a spudger by releasing the small clips on the sides.
      • Remove the multiple layers of film from the TV.
      • The foils must be reinstalled later in the same order. Don't swap them.
      • Glue the scattered lenses back on, e.g. with superglue.
      • Make sure that the 3 pins on the scatter lenses are correctly seated on the LED strip when you stick them on.
      • Congratulations! You managed to fix your TV!
Work the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0HelloMacOScrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2958738:0crwdne2958738:0 ›
amusing3136
crwdns2935283:011/27/21crwdne2935283:0
297 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 87
crwdns2959996:0crwdne2959996:0 2,082
