Fitbit Charge HR Battery Replacement
  1. Fitbit Charge HR Battery Replacement, Fitbit Charge HR weak Battery Repair / Replacement tutorial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fitbit Charge HR Battery Replacement, Fitbit Charge HR weak Battery Repair / Replacement tutorial: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inside your Fitbit Charge HR
  2. Fitbit Charge HR Battery Replacement, Tools needed to replace Fitbit Charge HR battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You'll need some plastic bits to separate the band, plus a torx T3 driver, new battery and a soldering iron.
  3. Fitbit Charge HR Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This repair only works on the Fitbit Charge HR model, not the older Charge without heart rate. The batteries are different.
  4. Fitbit Charge HR Battery Replacement, Separate the band from the electronics casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start by removing the 4 torx screws
  5. Fitbit Charge HR Battery Replacement, Take your time and be careful of the fragile plastic: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The assembly is briskly snapped into place. You'll need to separate the sides of the housing with a small plastic tool and your finger nail (or two plastics). Be careful, as the housing can fracture with too much force.
  6. Fitbit Charge HR Battery Replacement, A small torx driver is required.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fitbit Charge HR Battery Replacement, A small torx driver is required.: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once removed, there are 2 torx screws holding the circuit board in place. Remove these, and carefully pry the board out
  7. Fitbit Charge HR Battery Replacement, Prepare to solder!: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fitbit Charge HR Battery Replacement, Prepare to solder!: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Fitbit is very light and hard to hold, so it is recommended to tape the board in place when soldering.
  8. Fitbit Charge HR Battery Replacement, Understand the risk to your device.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note: You can permanently damage your device. Be careful with the assembly, and splice one or both wires before removing the old battery to prevent a short. Do not mistake the round buzzer for a battery. It is not !
  9. Fitbit Charge HR Battery Replacement, Test your work before you re-assemble.: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After replacing the bad battery, plug in the charger for at least 20 minutes. Then remove the charger to confirm you have a working replacement.
crwdns2935229:033crwdne2935229:0
martysummer
crwdns2935283:002/18/13crwdne2935283:0
943 crwdns2915208:0crwdne2915208:0
crwdns2947412:023crwdne2947412:0
if you have the manual dexterity and intellect to replace the battery on a Fit bit Charge HR, why can't you do it on. "Charge" plain model I have 3 of these with dead batteries?
coljwm - crwdns2934203:0crwdne2934203:0
The battery on the original Fitbit tracker is different than the newer Fitbit HR. If you can find a battery that fits, it would work.
martysummer - crwdns2934203:0crwdne2934203:0
Where can I buy a replacement battery for my charge hr? Fitbit wants me to buy a new Fitbit which is inexcusable since the watch is only 16 months old
Evan - crwdns2934203:0crwdne2934203:0
They sell them on Amazon for $10.95. Has only one review for 2 stars. Trying to decide if I should order one. Caveat emptor!
Scott McKernon -
Can you give me the size of the battery?
Bajmóczy Géza - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 329
crwdns2942667:0crwdne2942667:0 158,052
