Fitbit Blaze Battery Replacement
  1. Fitbit Blaze Battery Replacement, Wristband: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fitbit Blaze Battery Replacement, Wristband: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit Blaze Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit Blaze Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
  4. Fitbit Blaze Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place device screen face down and locate the four screws attaching the back cover.
    • Use a T3 torx head or T3 torx screwdriver to remove the four screws.
  5. Fitbit Blaze Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
    • Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
    • Insert and lift the plastic opening tool to release the ribbon.
    • Only a small force when lifting the plastic connector is needed to avoid damage.
  6. Fitbit Blaze Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the back and set aside, locate the three screws attaching the motherboard.
    • Use a PH000 head or a PH000 screwdriver to remove the three screws.
  7. Fitbit Blaze Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic spudger tool on the ribbons connected to the motherboard.
    • Insert the tool under the ribbon and lift to release the connection.
  8. Fitbit Blaze Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and push the motherboard to the side to uncover the 167mAh battery.
    • Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
    • Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
  9. Fitbit Blaze Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fitbit Blaze Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the motherboard backwards and locate the metal pins from the battery soldered to the board.
    • Desolder the connection to remove the battery, desolder the battery connector itself if desired as well.
    • Follow this guide on how to solder and desolder connectors Soldering Guide
    • Excessive heat will damage the components, so do not apply the soldering iron to the component for long amounts of time.
crwdns2935229:062crwdne2935229:0
Adrian Borrego
crwdns2935283:002/20/17crwdne2935283:0
2,242 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S3-G3, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team S3-G3, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S3G3
crwdns2947412:055crwdne2947412:0
Where can I buy this battery?
Please contact fred@doble.com.br
Frederico Araujo - crwdns2934203:0crwdne2934203:0
no answer for:
Pierre Therien - crwdns2934203:0crwdne2934203:0
Looking for this battery as well; mine lasted exactly 1 year. 7 days now down to hours, the surge did the same thing, maybe my last Fitbit watch ever! Disappointed to say the least.
Darrell Way - crwdns2934203:0crwdne2934203:0
I found a battery, 3.7 volt at 165mAh in the same style, should be close enough but I do not have the size of the factory battery, if anyone has taken theirs apart, can you post up the measurements in mm? thanks
I can't find the battery anywhere either. Would love some advice. Tried Amazon, AliExpress, eBay and Google in general.
Chris Wilson - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 132,859
