First Alert Smoke Alarm 9120B Battery Replacement
  1. First Alert Smoke Alarm 9120B Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the alarm by rotating it counter clockwise in the mount.
    • The alarm should fall off once rotated enough. The cable should be the only thing holding it in place if done correctly.
  2. First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the cable from the alarm.
    I can’t unplug the cable from the alarm
    Jerusalem - crwdns2934203:0crwdne2934203:0
  3. First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the catch on the top left of the alarm to open the battery compartment.
    Absolutely DOES NOT work! Pressed down on tab, but drawer would not budge. Forcefully pushed down on tab and ridiculously forced open drawer - it broke upon “opening.” Upon much closer investigation, I can clearly tell it would NEVER open as “designed.” Pulled 9v battery, and alarm is still beeping (as it did all night). Yes, it is unplugged from ceiling.
    Daniel Oddo - crwdns2934203:0crwdne2934203:0
  4. First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery and dispose of it properly.
    • Replace the old battery with a new 9V battery and close the compartment.
    • You should hear a click to know that the compartment is secured.
    This is horribly designed as it's very hard to remove the battery and I can't insert a new one
    Frank - crwdns2934203:0crwdne2934203:0
  5. First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Line up the holes of the cable on the mount with the pins on the alarm.
    • Reconnect the cable on the mount to that on the alarm.
    • It should insert itself with minimal force.
  6. First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the alarm into the mount.
  7. First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 First Alert Smoke Alarm 9120B Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the alarm clockwise until it does not turn anymore. This makes sure the alarm is secured.
    How do I reattach the battery door if it came off?
    Sheryl Hage - crwdns2934203:0crwdne2934203:0
    Just open the battery compartment,slip out the battery
    Now slip a new 9 v in place
    Don’t have to remove entire thing!
    Henk van Wyk - crwdns2934203:0crwdne2934203:0
    is there anyway to safely take it apart and see what inside
    MckayleGaymesYT - crwdns2934203:0crwdne2934203:0
    my alarm is hardwired to my house electrical. It has no battery but is chirping - one chirp per minute (indicating it needs a new battery?). I followed your steps & inserted a brand new 9v battery & reattached the unit to ceiling. The one chirp each minute won’t stop. What do I do?
    Kim Cailteux - crwdns2934203:0crwdne2934203:0
    What brand is your smoke detector?
    Toon Konings -
Miggy Reyes
crwdns2935283:002/15/21crwdne2935283:0
219 crwdns2915208:0crwdne2915208:0
Texas Tech, Team S3-G17, Cowan Spring 2021 crwdns2935289:0Texas Tech, Team S3-G17, Cowan Spring 2021crwdne2935289:0
TTU-COWAN-S21S3G17
crwdns2947412:05crwdne2947412:0
How do I disconnect the cable? Seems very tight and cannot disconnect.
Jeanne O - crwdns2934203:0crwdne2934203:0
This is related to first alert smoke alarm 9120B. Can not remove connecting cable from alarm. Is very tight. So unable to change battery. Any suggestions?
These alarms suck! Pressing the tab and the battery compartment does NOT pop open. I needed a knife to pry it open, and then it had to be forced close. NOT user error! The plastic pins that hold the battery compartment closed don't move out of the way enough to allow opening.
James Durso - crwdns2934203:0crwdne2934203:0
I replaced the battery and it is still beeping, reset the smoke alarm. What should I do now?
Donald Sandford - crwdns2934203:0crwdne2934203:0
Buy and install a new alarm. It’s easier than trying to fix on.
Stephen Taylor - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 39
crwdns2936753:07crwdne2936753:0 277
crwdns2936753:030crwdne2936753:0 1,278
crwdns2942667:0crwdne2942667:0 48,482
