First Act MA2039 Damaged Wire Replacement
  1. First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the speaker with its front side facing down.
    • Use a Phillips #0 screwdriver to remove the two 25 mm screws from the left and right sides of the battery cartridges.
    • Open both lids to the battery cartridges.
  2. First Act MA2039 Damaged Wire Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 First Act MA2039 Damaged Wire Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 First Act MA2039 Damaged Wire Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As you begin to lift the back panel off the amplifier, push the battery terminals through the open slots of the battery cartridges.
    • Use your fingers to prop the back panel and lift it away from the amplifier.
    • Lift the back panel off completely and set it to the side.
  3. First Act MA2039 Damaged Wire Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 First Act MA2039 Damaged Wire Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 First Act MA2039 Damaged Wire Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the back panel off, this will help make space for the silver compartment to be removed.
    • Unscrew four 25 mm screws with a Phillips #0 screwdriver from the top of the amplifier.
    • Press firmly on the input jack and tone adjustment knob of the silver compartment to free it from its resting position.
  4. First Act MA2039 Damaged Wire Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 First Act MA2039 Damaged Wire Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 First Act MA2039 Damaged Wire Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the silver compartment so that you have a clear visual of the motherboard and its components.
    • For effective work on the wiring, lodge the compartment on top of the back portion of the amplifier.
    • Check the wiring components for blown fuses or damaged connections.
  5. First Act MA2039 Damaged Wire Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the silver compartment to see where the wires are further connected.
    • Make sure that the terminals from the circuit to the amplifier are connected securely.
    • Check to see if there is loose wiring from the motherboard.
    • If there is damaged wire to the amplifier or motherboard in the silver compartment, refer this Soldering guide to replace wires and fix connections.
Luke VanBuskirk
crwdns2935283:004/05/18crwdne2935283:0
279 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team S1-G5, Johnson Spring 2018 crwdns2935289:0Linn Benton Community College, Team S1-G5, Johnson Spring 2018crwdne2935289:0
LBCC-JOHNSON-S18S1G5
crwdns2942667:0crwdne2942667:0 687
