Fender Starcaster Tuning Heads Replacement
crwdns2869540:0crwdne2869540:0: 3.6K
3
22
103
3,615
crwdns2955950:0crwdne2955950:0: 4
crwdns2960002:01crwdne2960002:0, crwdns2960008:03crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 15 - 30 crwdns2931279:0crwdne2931279:0
If the tuners have broken, become excessively lose, or seized, they will require replacement.
    1. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
    2. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
    3. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
    1. Fender Starcaster Tuning Heads Replacement, Tuning Heads: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster Tuning Heads Replacement, Tuning Heads: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a wrench, remove the nuts around each tuning head post.
    2. Fender Starcaster Tuning Heads Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Starcaster Tuning Heads Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Next, remove the threaded retainer sleeve from each post.
      • Don't forget the washer.
    3. Fender Starcaster Tuning Heads Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster Tuning Heads Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Next, remove the screws from the backside of each tuner.
    4. Fender Starcaster Tuning Heads Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Starcaster Tuning Heads Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Finally, remove the tuning machine assembly from the headstock.
Christopher Hartigan
crwdns2935283:009/10/14crwdne2935283:0
164 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 5-3, Prince Fall 2014 crwdns2935289:0Pasco Hernando, Team 5-3, Prince Fall 2014crwdne2935289:0
PHSC-PRINCE-F14S5G3
crwdns2931471:09crwdne2931471:0
Does the 2013 Starcaster take a 10mm tuning peg?
Brian Seese - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is only the removal. Nothing After step 7. What about the actual replacement? What did you replace them with? Did it involve any machining?
Richard Caruso - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is only the removal. What about the actual replacement? What did you replace them with? Did it involve any machining?
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 103
crwdns2959996:0crwdne2959996:0 3,615
