Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment
  1. Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment, Bridge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment, Bridge: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by removing the strings from your instrument, loosen the tuning pegs until there is no tension and you can simply remove the strings.
    • Pull the strings out from the bridge, and set them aside somewhere, unless you are also replacing your strings.
  2. Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your Phillips screwdriver to unscrew the screws on the bridge one by one, the order in which you remove them is irrelevant.
    • Pick up the bridge once you have removed all the screws.
  3. Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Line up the new bridge with the existing screw holes as best as possible, the new bridge might not line up the exact same as the old one, but it will line up properly as long as it is still a four-string bridge.
    • Screw in the screws starting with the outer two so as to not allow the bridge to shift as you screw in the remaining screws.
  4. Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The next step is possible to do without the strings on, but if you want "live feedback" then you will put the strings back on.
    • If you aren't well acquainted in the restringing process, I recommend learning how to do so best in another tutorial as I am glossing over it.
    • Feed the strings through the hole in the bridge, like you did in step 1 but in reverse, be sure they are in the correct order
    • Tighten the strings and tune them, it will be necessary for them to be in tune for the aforementioned "live feedback" to work
  5. Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fender Squier Electric Bass Bridge Removal/Replacement/Adjustment: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • By tightening or loosening the screw on the outside of the string you can adjust the cylinders on the bridge called bridge saddles to be closer or farther.
    • Think of adjusting the bridge saddles as adjusting the action on the other end of the guitar, which is useful to be able to do, due to their proximity to the pickups.
You might want to hold onto your old bridge in case there are any complications with your new bridge, also you never know when you might need a spare assuming your bridge is still usable. Thank you for reading my guide, I hope it helped you.
Caleb Redwine
crwdns2935283:002/24/25crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 1-11, Kapoor Spring 2025 crwdns2935289:0Austin Community College, Team 1-11, Kapoor Spring 2025crwdne2935289:0
AUSTINCC-KAPOOR-S25S1G11
crwdns2942667:0crwdne2942667:0 73
