The brakes on anything that moves are practically the most important part. One of the most frightening feelings is pulling a brake lever and not getting a response. With this guide I hope to never make this a reality for anyone.
This guide contains information on how to replace the brake pads on a 2013 Felt Z85 Road Bike. This guide only requires one tool (4mm allen key) and is fairly straightforward.
This guide can also be used as a reference for any modern road bike with Dual-Pivot brakes.
Pull up on brake-release lever to spread pads for easy access.
Release lever on the right side of the wheel.
Loosen left nut on wheel until wheel comes free.
Locate Brake Caliper.
Use 4.0 mm allen key to remove main bolt.
Rotate counterclockwise to loosen.
Repeat step 2 to remove the pad on the other side.
Brake Pad: The item being replaced.
Spacer: This item will be reused.
Washer: This item will be reused.
4 mm hex bolt.
