Felt Z85 Brake Pad Replacement
  1. Felt Z85 Brake Pad Replacement, Remove Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Felt Z85 Brake Pad Replacement, Remove Wheel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Felt Z85 Brake Pad Replacement, Remove Wheel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on brake-release lever to spread pads for easy access.
    • Release lever on the right side of the wheel.
    • Loosen left nut on wheel until wheel comes free.
  2. Felt Z85 Brake Pad Replacement, Remove Pad(s): crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Felt Z85 Brake Pad Replacement, Remove Pad(s): crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Felt Z85 Brake Pad Replacement, Remove Pad(s): crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate Brake Caliper.
    • Use 4.0 mm allen key to remove main bolt.
    • Rotate counterclockwise to loosen.
    • Be careful not to lose both the washer and spacer found in-between the bolt and the brake pad mounting hole.
    • Repeat step 2 to remove the pad on the other side.
  3. Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Brake Pad: The item being replaced.
    • Spacer: This item will be reused.
    • Washer: This item will be reused.
    • 4 mm hex bolt.
    • Note order of mounting hardware for reinstall.
Ryan Marschall
crwdns2935283:010/11/14crwdne2935283:0
123 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-21, Donnelly Fall 2014 crwdns2935289:0USF Tampa, Team 1-21, Donnelly Fall 2014crwdne2935289:0
USFT-DONNELLY-F14S1G21
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,080
