I’ve decided to take you along with me and create a simple manual of how to replace a shower curtain bar which is very important for many reasons. One reason is for privacy reasons and the other for not damaging the washroom tiles by getting water on them.
Use a measuring tape to measure the length of the rod in order to make sure the replacement is the same length.
Using your flathead screwdriver or your screwdriver gun, loosen the screw by turning it counterclockwise.
Remove the old rod as well as the brackets.
Use disinfecting wipes to clean the area on the wall where the old brackets were.
Grab your new shower curtain rod.
If preferred, hold your old shower curtain rod against your new one to make sure they are both the same size.
Lastly, using your flat head screwdriver or screwdriver gun, rotate the screw clockwise to tighten the screw.
To reassemble your device, follow these instructions in reverse order
