Fast Fix Screen Replacement
  1. Fast Fix Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide both battery latches to release cover.
    • Remove battery.
  2. Fast Fix Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the M2.5 X 5mm phillips screw for the CD drive.
    • Remove the CD drive.
  3. Fast Fix Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen 2 screws on access door.
    • They cannot be removed
    • Remove the access door.
  4. Fast Fix Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 12 M2.5 X 5MM Phillips bottom palm rest screws.
  5. Fast Fix Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small screwdriver to press in the keyboard latches.
    • Remove the keyboard.
    • Unplug the keyboard cable at the ZIF connection.
    The Zif Connector has to be opened before taking the cable out
    this applies to any Zif connector
    Tech, Tunes And Textures - crwdns2934203:0crwdne2934203:0
  6. Fast Fix Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the palm-rest cable by releasing the ZIF latch and pulling the wire out.
    • Remove 5 M2.5 X 5mm Phillips and 2 M2 X 3mm Phillips palm-rest screws.
  7. Fast Fix Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a small flat screwdriver to pry the palm-rest off of the computer.
  8. Fast Fix Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wireless antenna
    • Remove the LCD cable
  9. Fast Fix Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 1 M2.5 x 5mm Phillips left hinge screw and 2 M2.5 x 5mm Phillips right hinge screw.
  10. Fast Fix Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the LCD bevel using a small flat screwdriver.
  11. Fast Fix Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 M2 X 3mm Philips LCD screws.
  12. Fast Fix Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the screen cable and remove the screen.
Carl Kangas
crwdns2935283:010/01/17crwdne2935283:0
182 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team S3-G8, Galliah Fall 2017 crwdns2935289:0Michigan Tech, Team S3-G8, Galliah Fall 2017crwdne2935289:0
MTU-GALLIAH-F17S3G8
Hello good day, I have a question, I have managed to replace the screen and the computer started the first time without problems, but after I started it again the computer did not turn on the screen again, will you have any possible solution?
vikingo1ero - crwdns2934203:0crwdne2934203:0
Hi, Did you ever fix this problem? I'm having the same issue.
Chris Terry -
crwdns2942667:0crwdne2942667:0 3,122
