Fast Fix Screen Replacement
crwdns2869540:0crwdne2869540:0: 3988
5
29
94
3,988
crwdns2955950:0crwdne2955950:0: 3
crwdns2960002:01crwdne2960002:0, crwdns2960008:02crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 5
crwdns2959974:05crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:045crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
This guide can be used to remove and replace a screen on a Dell Insprion 15-3521. The tools needed are a small Phillips screwdriver, and a small flat screwdriver or like prying device.
    1. Fast Fix Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide both battery latches to release cover.
      • Remove battery.
    2. Fast Fix Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the M2.5 X 5mm phillips screw for the CD drive.
      • Remove the CD drive.
    3. Fast Fix Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Loosen 2 screws on access door.
      • They cannot be removed
      • Remove the access door.
    4. Fast Fix Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove 12 M2.5 X 5MM Phillips bottom palm rest screws.
    5. Fast Fix Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a small screwdriver to press in the keyboard latches.
      • Remove the keyboard.
      • Unplug the keyboard cable at the ZIF connection.
    6. Fast Fix Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the palm-rest cable by releasing the ZIF latch and pulling the wire out.
      • Remove 5 M2.5 X 5mm Phillips and 2 M2 X 3mm Phillips palm-rest screws.
    7. Fast Fix Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a small flat screwdriver to pry the palm-rest off of the computer.
    8. Fast Fix Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the wireless antenna
      • Remove the LCD cable
    9. Fast Fix Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 1 M2.5 x 5mm Phillips left hinge screw and 2 M2.5 x 5mm Phillips right hinge screw.
    10. Fast Fix Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off the LCD bevel using a small flat screwdriver.
    11. Fast Fix Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4 M2 X 3mm Philips LCD screws.
    12. Fast Fix Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fast Fix Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unplug the screen cable and remove the screen.
crwdns2935229:05crwdne2935229:0
crwdns2935291:0crwdne2935291:0
Carl Kangas
crwdns2935283:010/01/17crwdne2935283:0
236 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team S3-G8, Galliah Fall 2017 crwdns2935289:0Michigan Tech, Team S3-G8, Galliah Fall 2017crwdne2935289:0
MTU-GALLIAH-F17S3G8
Hello good day, I have a question, I have managed to replace the screen and the computer started the first time without problems, but after I started it again the computer did not turn on the screen again, will you have any possible solution?
vikingo1ero - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, Did you ever fix this problem? I'm having the same issue.
Chris Terry - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 94
crwdns2959996:0crwdne2959996:0 3,988
