Maintaining a comfortable and healthy home environment involves several crucial tasks, and one that often goes overlooked is replacing the air filter in your air conditioning (AC) system. In this short guide, I will explore how easy and quick it is to replace your AC air filter regularly. By understanding the significance of this simple maintenance task, you can ensure cleaner indoor air, improve energy efficiency, and prolong the lifespan of your AC system. Let's dive in and discover how to replace your AC air filter at home!
Locate the air filter panel in your home.
Take out the old air filter from its housing.
Install the new air filter! Take the new air filter and insert it into the filter housing, ensuring it is placed correctly according to the airflow direction indicated on the filter.
Replace the access panel. If you had to remove an access panel, carefully put it back in place and secure it with screws or clips.
Turn on the AC system.
With the new filter installed and the access panel securely in place, it's time to turn the AC system back on.
