Use this guide to remove the plastic midframe from your Fairphone to access internal components.
With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
Slide the back cover down and remove it from the phone.
Use a fingernail in this indentation to push the battery toward the top of the phone
Pull the battery out away from the phone.
Remove the battery from your Fairphone.
Use your finger to slide the SIM card straight down out of its tray.
Remove the SIM card from your Fairphone.
If you have a microSD card, use your finger to slide it straight out of its slot.
Remove the microSD card from your phone.
Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
Use an opening pick to carefully pry the midframe away from the display assembly.
Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
Carefully round the corner, separating the midframe from the display assembly.
Run the opening pick and pry along the top seam.
Separate any remaining clips and remove the midframe from the phone.
Use the tip of a spudger to pry the speaker off of the midframe.
Remove the speaker from the midframe.
crwdns2935229:010crwdne2935229:0
