Fairphone 1 Display Assembly Replacement
  1. Fairphone 1 Display Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 Display Assembly Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from your Fairphone.
  5. Fairphone 1 Display Assembly Replacement, SIM and MicroSD Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, SIM and MicroSD Card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, SIM and MicroSD Card: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone 1 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone 1 Display Assembly Replacement, Midframe Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone 1 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone 1 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone 1 Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone 1 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone 1 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone 1 Display Assembly Replacement, Motherboard Assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Motherboard Assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Motherboard Assembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to remove the volume rocker and power buttons from the display assembly.
    • During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
  14. Fairphone 1 Display Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
  15. Fairphone 1 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
  16. Fairphone 1 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
    • Use tweezers to pull the digitizer cable away from its socket on the motherboard.
  17. Fairphone 1 Display Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
  18. Fairphone 1 Display Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
    • Gently lift the top end of the motherboard up to expose the display data cable.
    • The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
  19. Fairphone 1 Display Assembly Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
  20. Fairphone 1 Display Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the display assembly.
  21. Fairphone 1 Display Assembly Replacement, Wi-Fi Antenna Daughterboard: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful to pry on the connector, not the socket.
  22. Fairphone 1 Display Assembly Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to flip open the tab on the daughterboard data cable ZIF connector.
    • Use tweezers to pull the daughterboard data cable away from its socket.
  23. Fairphone 1 Display Assembly Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws securing the Wi-Fi daughterboard to the display assembly:
    • Two 2.5 mm Phillips #000 screws
    • One 1.6 mm Phillips #000 screw
  24. Fairphone 1 Display Assembly Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Wi-Fi antenna daughterboard is held to the front assembly by mild adhesive.
    • Use tweezers to gently pry the board up and remove it from the phone.
  25. Fairphone 1 Display Assembly Replacement, Earpiece Speaker: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Earpiece Speaker: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Earpiece Speaker: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The earpiece speaker is held to the back of the display assembly with some mild adhesive.
    • Use the tip of a spudger to gently pry the speaker up from the display assembly.
    • Remove the speaker.
  26. Fairphone 1 Display Assembly Replacement, Display Assembly: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Display Assembly: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement, Display Assembly: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the antenna interconnect cable from the display assembly.
    • The three sections of the cable with exposed metal fit into the grounding clips on the side of the display assembly.
  27. Fairphone 1 Display Assembly Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber guide from the recess near the front facing camera hole.
    • Be sure not to lose this rubber stopper, transfer it to the new display.
  28. Fairphone 1 Display Assembly Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 1 Display Assembly Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber guide to the right of the earpiece speaker recess.
    • Your replacement display will have a piece of yellow tape covering the touch sensor chip. Do not remove this tape; if you do, your phone may not work after reassembly.
crwdns2935229:0102crwdne2935229:0
Andrew Optimus Goldheart
crwdns2935283:010/17/09crwdne2935283:0
511,959 crwdns2915208:0crwdne2915208:0
crwdns2935297:0407crwdne2935297:0
Staff
crwdns2935297:023,377crwdne2935297:0
crwdns2947412:016crwdne2947412:0
So far, so good.
My display is replaced now.
Unfortunately, removing the motherboard easily destroyed the camera, which didn't come up with the motherboard, being glued to display at the back.
So now I gotta get a new camera and do the hole thing again -.-
Atrocio - crwdns2934203:0crwdne2934203:0
step 20:
Watch out not to loose the two rubber things of step 27 and 28 while taking out the motherboard. I foud the small one floor.
Koen Go - crwdns2934203:0crwdne2934203:0
The Camera is not mentioned at all. It's glued to the Display and yet still working, it can't focus anymore. So I might have to get a new one as well.
Juliane Grossmann - crwdns2934203:0crwdne2934203:0
Screen fixed :-) thanks for the guide!
Watch the glued camera on step 19...
Aitor - crwdns2934203:0crwdne2934203:0
Awesome! Did it, and everything still works. Mighty pleased with myself. Thank you, iFixit!!!
Meike Hensmann - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 162
crwdns2942667:0crwdne2942667:0 37,264
