Fahrenheit FHT 125PRMR Power Cord Replacement
  1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fahrenheit FHT 125PRMR Power Cord Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fahrenheit FHT 125PRMR Power Cord Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
    • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
  5. Fahrenheit FHT 125PRMR Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
Joshua Potts
crwdns2935283:009/29/16crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-2, Harley Fall 2016 crwdns2935289:0IUPUI, Team 2-2, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S2G2
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - crwdns2934203:0crwdne2934203:0
Where do you buy the power cord?
Dominique - crwdns2934203:0crwdne2934203:0
probably available at electronic store
john john - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,647
