Fahrenheit FHT 125PRMR Heating Plate Replacement
  1. Fahrenheit FHT 125PRMR Heating Plate Replacement, Heating Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using Philips head (PH1) remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
  5. Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using Philips head (PH1) remove the two 4 mm silver screws on the sides of dial panel cover
  6. Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using Philips head (PH00) to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
  7. Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  9. Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 3 sliver screws (3mm) (PH1) from the motherboard.
  10. Fahrenheit FHT 125PRMR Heating Plate Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Omar El Mounayri
crwdns2935283:009/29/16crwdne2935283:0
61 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-2, Harley Fall 2016 crwdns2935289:0IUPUI, Team 2-2, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S2G2
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 2,591
