Fahrenheit FHT 125PRMR Dial Replacement
  1. Fahrenheit FHT 125PRMR Dial Replacement, Dial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Philips head #1 screwdriver remove the two 6mm black screws on both sides of the dial panel cover.
  5. Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Philips head #1 screwdriver remove the two 4mm silver screws on both sides of the dial panel cover.
  6. Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Philips head #00 screwdriver remove the 4mm silver screw from the center of the dial.
    • Remove the dial after the screw is removed with either your hand or a plastic opening tool.
  7. Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Dial Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Nicolas Moreau
crwdns2935283:009/29/16crwdne2935283:0
180 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-2, Harley Fall 2016 crwdns2935289:0IUPUI, Team 2-2, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S2G2
crwdns2942667:0crwdne2942667:0 1,312
