Nokia Lumia 530, RM-1017, RM-1019 - How to Master Reset the phone and bypass the Password Screen Lock or erase all personal content.
crwdns2936621:0crwdne2936621:0
1. Switch off device.
2. Press and hold the Power button until the phone vibrates.
3. Release the Power button and immediately press and hold down the Volume Down button. On the display will appears an exclamation mark
4. Press this sequence of keys: - Volume Up - Volume Down - Power button - Volume Down
5. The phone will restart and reset to its original factory settings.
Did you do it successfully?
crwdns2935229:046crwdne2935229:0
crwdns2947412:054crwdne2947412:0
Thanks for your support
I factory reset my Nokia model RM-1018. My IMEI # is completly clean and clear... so can I swap out my SIM card for another service provider?
Do I just change sim cards and turn on, and set up service?
work great....
Nice one more power to your elbow
Adi maddest commands ryt there im going to make cash with these no hard feelings
Thanks for your usefull advice
Thanks bro successfully working. GOOD
I'm trying to do this without an LCD on a Lumina 530. I get the vibration on step 2 -the phone turning on. Since i do not see an exclamation mark, I just hold the button for 15-20 seconds. Right before step 4 - the sequence I get another vibrate. After that I just push the buttons as directed but no more tactile feedback. I have NOOO idea if i'm wiping the device or not. No rebooting vibration - so I'm guessing that somewhere along the way I'm jumping the gun - right?
Can someone tell me the vibration feedback along the way that I should be paying attention to?
Or another way to do this - maybe?
Thanks!
just do these steps and wait for aprox 15 minutes because this process takes a lot of time complete the recovery
Thank you so much... it really works for me... Good day to you...
thanks for support
flight mode not remove problem on my phone
Lovely thanks :)
Thank you!It worked!
It just keeps restarting and showing the Microsoft symbol what do I do u can contact me at (Cell)#337-298-0132
Me too I have the same problem as you
Seidou -
great work thanx
i do the following instruction then it just starts up again please help you can email me at shevez80@hotmail.co.uk thanks
plz try thish........... press power button until vibret relese the power and press ,volume down,
now you click volume down,volume up ,volume down ,power,and volume down
mine dont work
i have nokia rm 1053 X+ and i already deleted system files at the heard reset time and also deleted all the files from sdstorage and format all storage location... and rebooting the mobile and now my mobile is not working... its not turning on :( can u pls help me?
You really saved me the trouble pal
I have a microsoft model rm 1077 and am trying to hard reset it because I've forgotten my unlock code. I've tried holding the volume down reset instructions above but I don't ever get the exclamation point to show. Any tips?
My Nokia 530 kept starting shutting down got blue screen with ☹ , followed instructions. The operation system reinstalled. Phone works perfectly. Running windows 8.1
Hw to reset Nokia RM 970 plz help
Ok now ask for a recovery key where do I get that. thanks for the heads up
Thanks a lot.
thank you kind sir
Idk what it did now my screen is frozen with a lightning bolt and a settings icon
Idk what it did to my phone but now its frozen showing a lightning bolt and a settings
In your case, i think, you need to charge your phone while resetting it.
make -
im doing that! what now?
Wow! This is great. It worked perfectly.
wow thanks it worked.. ithinkithink
I did that but now just h2 gears spinning
Is this the only way to by pass? I dropped my phone and it now reads that I have wait 1564946 minutes to try again! I have already had to reset to factory and lost all of my pics. I really do not want to have to do it again.
is there a way to by pass the locked screen without deleting everything? I dropped my phone and it now reads that I have to wait 1564494 minutes to try again!
My Nokia RM986 not remove the password and hard reset please help me…
My Nokia RM986 not remove the password and hard reset please help me and solve my problem…
it was very easy to understand, thanks a million for such idea.
I have seen de exclamation mark but da phone just restarts normally
mine is an RM 1067 and it’s showing Bitlocker recovery , and it says to remove this drive plug in the USB drive that has the bitlocker recovery key
Bit locker needs your recovery key to unlock your drive because the trusted platform module is not accessible for more information on how to retrieve this key go to http://windows.microsoft.com/recoverykey... for another pc or mobile device
press Enter to reboot and try again
Press ESC or windows key for more options
SUPER Awesome Guys… I should have googled this the first time i had trouble… Keep up the GREAT Job iFixit… Yall ROCK!!! Have a Blessed day
thank you sa video :D
PLEASE HELP ME,
I USE NOKIA 6. AND I USE MY FINGERPRINTS AS MY UNLOCK FOR DEVICE,
THEN SOMEHOW IT REQUIRED BACKUP PASSWORD BUT I FORGOT MY PASSWORD, THERE IS NO FACTORY RESET WHEN I USE UP BOTTON +POWER KEY nO DATA.
I WANT TO RECOVER USING MY GOOGLE ACCOUNT. PLEASE HELP ME. THANKS
After reset it ask me for reset protection notification key
I have a nokia model : Rm-1189 it was my father cell phone and now i want to use it but i dont know the securityhow do i remove the security.
Totally helped ! Kudos.
I forgot my password and tried to do a hard reset but i failed its just rebooting wth a display showing 4G LTE
I have seen reached the exclamation mark stage but the phone just restarts normally and did not perfom the hard reset.Model written in chinese bt RM-1010
Nice one, it works perfectly
Didn't work, lock screen says try again 3580807 minutes ! What do I do ?
Bro youre a genuis cant believe it works i have been trying for many days now not untill I came to your website.
Thanks again bro
how do I get this window pane remove so I can make outside calls
Tracy Sampson - crwdns2934203:0crwdne2934203:0
how wil i unlock my phone. have tried the above method but it did not work
obiagelipeter - crwdns2934203:0crwdne2934203:0
Thanks for the tip, it really works....
Malika Jones - crwdns2934203:0crwdne2934203:0
Hello! Thank you so much, it's working.
rufdoniedubalan - crwdns2934203:0crwdne2934203:0
yes, your methode is working bro
keep it up.
thank you
jay mobile - crwdns2934203:0crwdne2934203:0
thaaaaaaaaaaaaaaaaaaaaaaaNkssssssssssss bro
Ayesha yes shur - crwdns2934203:0crwdne2934203:0
yeah it was a great way of solving my problem yeah
qwekujunior - crwdns2934203:0crwdne2934203:0
Yes thank very helpful
Juliet Fraser - crwdns2934203:0crwdne2934203:0
thanks for the help
TAWFIQ GOMDA - crwdns2934203:0crwdne2934203:0
When i try to reset this happens....instead of showing to rounded gears..it shows a sign of a spark of lighting and one gear..and it just stuck like that.
Vincet - crwdns2934203:0crwdne2934203:0
what should i do...if that is the case..
Did hard reset however ph just keeps shutting down and restarting none stop. Nokia 530
toyota.sprinter.1984 - crwdns2934203:0crwdne2934203:0
So can anybody help me with my phone.
its working..
Ronilo Yap - crwdns2934203:0crwdne2934203:0
Nice one worked first time.
Stuart Wilson - crwdns2934203:0crwdne2934203:0
How do I update so that I can get messenger
After the factory reset my phone it went to the logo and stuck on that screen. What next?
Pauline Scaife - crwdns2934203:0crwdne2934203:0
it soo easy and simple
marveeosei2 - crwdns2934203:0crwdne2934203:0
How can I reset without a power button?
Fred Gallagher - crwdns2934203:0crwdne2934203:0
Thank you so much! That was exactly what I needed!
Almaz Berenike Bergk - crwdns2934203:0crwdne2934203:0
Thakns so much dear friend i can use my phone now
zafrullah ubwa - crwdns2934203:0crwdne2934203:0
I tried and it returned back to locked screen
Archibong James - crwdns2934203:0crwdne2934203:0
Omg. It didn't do the exclamation but acted like it was gonna open the phone with emergency locked screen and I pressed something and it asked me if I wanted to be put in safe mode! Good enuf for me!! THANK YOU
Blah - crwdns2934203:0crwdne2934203:0
Now it's on safe mode so hacker can't get in but it never factory reset. Is there something else I can try ? Or is the safe mode a product of the hacking?
Anyway it won't reset. Please help me
Blah -
