FS-200 Impulse Heat Sealer Heating Element Replacement
  1. FS-200 Impulse Heat Sealer Heating Element Replacement, Heating Element: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FS-200 Impulse Heat Sealer Heating Element Replacement, Heating Element: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the heat sealer from any power source and make sure the heat sealer isn't hot.
    • Lift the sealing arm and position it up and out of the way to create space for the replacement.
  2. FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a standard Phillips #2 screwdriver, remove the first two screws to detach the first metal panel.
  3. FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a standard Phillips #2 screwdriver, unscrew the remaining two screws to remove the second metal panel.
  4. FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the teflon strip to expose the heating element wire.
  5. FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a standard Phillips #2 screwdriver, unscrew the large single screw and remove the old heating element wire.
  6. FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the new heating element by placing one end of the wire onto the pin located beneath the arm lever.
  7. FS-200 Impulse Heat Sealer Heating Element Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stretch the wire across the base pulling it towards the corresponding screw hole. The pin from the first side will slide as you pull it tight.
    • Holding the heating element taught, line up the 2 holes and use a standard Phillips #2 screwdriver to screw in the large single screw.
AshleyDrake
crwdns2935283:001/21/25crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
Rose State College, Team 1-4, Kirkman Spring 2025 crwdns2935289:0Rose State College, Team 1-4, Kirkman Spring 2025crwdne2935289:0
ROSE-KIRKMAN-S25S1G4
crwdns2942667:0crwdne2942667:0 97
