FLSUN QQ Leveling Sensor Replacement
Daniel Green
crwdns2944107:0crwdnd2944107:0Daniel Greencrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Sun 23, 2023crwdne2944111:0
20 - 40 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
If you own an original FLSUN QQ printer, upgrading the leveling sensor to a touch sensor will make leveling much easier. Here are the steps to upgrade to the new sensor.
  1. FLSUN QQ Leveling Sensor Replacement, Tools: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 2 hex wrenches that came with your printer
  2. FLSUN QQ Leveling Sensor Replacement, Parts: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • sensor
    • effector plate
    • connector cable
    • magnetic mount
  3. FLSUN QQ Leveling Sensor Replacement, Open the Printer: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FLSUN QQ Leveling Sensor Replacement, Open the Printer: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • remove 6 screws in the base of the printer
    • open the bottom cover
  4. FLSUN QQ Leveling Sensor Replacement, Swap the Sensor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FLSUN QQ Leveling Sensor Replacement, Swap the Sensor: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the connector with 2 white wires from the second green slot
    • Plug the connector for the new sensor into the second green slot.
  5. FLSUN QQ Leveling Sensor Replacement, Run the Cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • feed the cable through a convenient hole in the bottom plate
    • re-attach the plate to the printer with the 6 screws removed earlier
  6. FLSUN QQ Leveling Sensor Replacement, Remove Old Effector: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 FLSUN QQ Leveling Sensor Replacement, Remove Old Effector: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 FLSUN QQ Leveling Sensor Replacement, Remove Old Effector: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • pop off the fan ducts
    • Remove 3 smaller screws from the bottom of the effector
    • Remove 6 long screws from the connection points from the rods to the effector. (be careful to keep the tiny washers)
  7. FLSUN QQ Leveling Sensor Replacement, Install New Effector: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install fan ducts in new effector.
    • Attach the magnetic sensor dock to the new effector and mount the effector and heating element with the 3 small screws from earlier.
    • Reatach the whole assembly to the rods with the 6 long screws removed earlier.
  8. FLSUN QQ Leveling Sensor Replacement, Install New Sensor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FLSUN QQ Leveling Sensor Replacement, Install New Sensor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • plug the new sensor into the other end of the connector cable
    • attach the sensor to the magnetic mount
    • For the leveling sensor to work you will need new firmware.
    • Download it from https://www.dropbox.com/sh/p2jltxhkua629...
    • Unarchive the files.
    • Copy them to the root of an SD card
    • Make sure the printer is powered down
    • Insert the SD card with the firmware
    • Power on the printer.
    • The printer will update it's firmware.
    • Congratulations your QQ is now upgraded!
Daniel Green
crwdns2935283:002/08/15crwdne2935283:0
1.137 crwdns2915208:0crwdne2915208:0
crwdns2947412:013crwdne2947412:0
I followed the instructions and the Head started printing over 1 cm above the bed. I had to alter the Z offset to -18.5 mm. An icon appeared in the menu system “levelling_sw”, but does nothing when pressed. So there appears to be NO manual levelling option after carrying out the upgrade. Quite disappointing.
mike_biddell - crwdns2934203:0crwdne2934203:0
The “Leveling_sw” button adjusts the offset needed to use the leveling switch. (The offset is the distance between the nozzle and the bed when the switch is pressed.) There’s another Z-offset button that sets it to the default offset for using the leveling pad. You have to push the appropriate offset button before engaging the leveling option.
The QQ doesn’t have manual leveling without changing the Gen L board firmware to a different Marlin version.
CityZ -
hi, is not working for me. i can push the leveling button in screen so often, there´s no funktion, how could it be?
Ist it if my sensor have only two pins? Its the leveling sensor like anycubic delta is using.
Please explain or give me a link for these 3pin level sensor as you have shown in your pictures. Thanks.
Sven K - crwdns2934203:0crwdne2934203:0
If you are using the Anycubic switch, it might be wired differently than the Flsun version. If you look inside the sensor at the switch itself, there’s pins for normally-open (NO) and normally-closed (NC). The wire going to NC needs to be moved to NO.
On the control board, the wires need to go to Ground and Signal for the Z-min plug. Do not connect to the Voltage pin.
CityZ -
Have you got a link for the FLSUN levelling switch please.
David Houghton - crwdns2934203:0crwdne2934203:0
Hi David
The link is in step 2: FLSUN QQ Leveling Sensor Replacement
Unfortunately it looks like the module is no longer available.
Daniel Green -
hello,
can i print the effector plate ? link stl?
or can i bye? link?
charly
Charly Cremers - crwdns2934203:0crwdne2934203:0
Hi Daniel, i buy the FLSUN QQ and there ist a leveling pad and a leveling switch ,but i have not the connector cable .Can you please tell me where i can get one ? maybe on amazon.
Best Regards
Elmo Kan - crwdns2934203:0crwdne2934203:0
Hi Elmo
I don't know where you can buy the cable. It came with the switch when I bought mine.
FLSUN has a new website http://www.flsun3d.com/
Try contacting support through the website.
Daniel Green -
i have the Makerboard Robin mini V2.0. there is a diff to your mainboard to connect the switch … where i have to connect my original FLSUN switch???
and
is the firmware from your instruction the right for my board?
Mike - crwdns2934203:0crwdne2934203:0
I think they switched to the Robin mini for the QQ-S so no I don't think the firmware I posted is for your machine.
Daniel Green -
Hi, what does the Z offset need to be set to after this modification, and which option is used to change it please?
jamesqb2001 - crwdns2934203:0crwdne2934203:0
The z-offset will depend on your machines physical parameters. Adding the switch should not impact the z-offset, but updating the firmware could reset it to default. I will try to update these instructions with steps to calibrate z-offset. Sadly I don't have time at the moment so it may take some time. You might be able to get some help from one of the Facebook groups.
Daniel Green -
crwdns2942667:0crwdne2942667:0 8,070
