Hello this is actually a cleaning for an FDHD Drive but since they didn’t have an option for cleaning I picked disassembly.
It’s best to pull Down and twist to pull the spring off
Once again pull and twist movement
lift up on the really tiny tab with a flat blade screwdriver and slide it off
It may seem a little bit tricky at first but only push the ejection lever about halfway in
Remove these two screws and lift off the motor
Note: I did not have the second screw.
Unplug the motors 3-pin connector to make it easier
Thank you for using my guide just clean any places where metal touches metal and reassemble
