Ezonics EZ-307 Main Board and USB Cable Replacement
  1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Get Tools: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • A Phillips Head Size Zero Screw Driver
  2. Ezonics EZ-307 Main Board and USB Cable  Replacement, Detach the Base: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips-head screwdriver, remove each of the 3 screws from the underside of the camera head.
  3. Ezonics EZ-307 Main Board and USB Cable  Replacement, Set Aside the Base: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull back the base and set it aside.
    • Be careful not to pull out the USB cable attachment when taking off the base
  4. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the white connector with the red, green, white & black cord with your fingers. This connector is the end of the USB cable.
  5. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press tab on inside of device to release silver ring.
    • Gently remove top (silver) ring of lens casing with your fingers.
  6. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove inner casing of the lens (silver with a black ring).
    • Be careful not to break the small notch at the top, which holds the inner casing in place.
  7. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the small, black, ridged inner ring around the lens with your fingers.
  8. Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the lens counterclockwise with your fingers.
  9. Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the hollow outer casing so that you can see inside of it.
    • Gently pull out main board with fingers.
  10. Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your new board into the outer casing. Be sure that it rests firmly between the sets of rails on either side.
  11. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the lens piece in clockwise and then insert black ring around the lens.
  12. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Line up notch on inner lens casing (silver with black ring) with notch on body of camera. Gently push it into place, being sure not to break the notch.
    • Insert the silver ring. You should hear it click into place.
  13. Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the camera in one hand with the hollow side facing up.
    • Hold the USB cable in your other hand with the four small holes facing up.
    • Plug the USB cable into the port.
  14. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the USB cord in the notch at the base of the camera bottom.
    • Place the bottom back onto the camera top.
  15. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Line up the base of the camera with the screw holes.
    • Use a Phillips-head screwdriver to twist the three screws back into place.
Lyndsi
crwdns2935283:010/13/14crwdne2935283:0
7 crwdns2915208:0crwdne2915208:0
Ohio State, Team 1-5, Mccook Fall 2014 crwdns2935289:0Ohio State, Team 1-5, Mccook Fall 2014crwdne2935289:0
OSU-MCCOOK-F14S1G5
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 1,086
