Expansion Bay Prereq
crwdns2862623:0crwdne2862623:0
crwdns2948751:0crwdne2948751:0
  1. Expansion Bay Prereq, Before you begin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Expansion Bay Prereq, Before you begin: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Expansion Bay Prereq, Remove the touchpad spacers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the touchpad spacers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the touchpad spacers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  3. Expansion Bay Prereq: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the same procedure for the other touchpad spacer.
  4. Expansion Bay Prereq, Remove the touchpad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the touchpad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the touchpad: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  5. Expansion Bay Prereq, Remove the keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the keyboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  6. Expansion Bay Prereq, Remove the numpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the numpad: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the numpad: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  7. Expansion Bay Prereq, Disconnect the midframe cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Expansion Bay Prereq, Disconnect the midframe cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the black pull tab on the midframe cable press connector.
    • Lift up to disconnect the midframe cable.
  8. Expansion Bay Prereq, Loosen the midframe screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Expansion Bay Prereq, Loosen the midframe screws: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The midframe screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
    • During reassembly, follow the order (starting with 2) to reinstall the screws across the midframe evenly.
  9. Expansion Bay Prereq, Remove the midframe: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Expansion Bay Prereq, Remove the midframe: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
  10. Expansion Bay Prereq: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Expansion Bay Prereq: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the midframe off the laptop and remove it.
    • During reassembly, make sure the midframe sits evenly on its alignment pegs before tightening the screws.
  11. Expansion Bay Prereq, Loosen the battery screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Expansion Bay Prereq, Loosen the battery screws: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the battery.
  12. Expansion Bay Prereq, Remove the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the battery: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the black pull tab at the top of the battery.
    • Lift the pull tab to disconnect the battery connector.
    • Remove the battery.
  13. Expansion Bay Prereq, Lift the interposer door: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Expansion Bay Prereq, Lift the interposer door: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the interposer door by its black pull tab and let it rest upright.
  14. Expansion Bay Prereq, Loosen the interposer screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Loosen the interposer screws: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Loosen the interposer screws: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you have the graphics module installed, your interposer will have four screws. Otherwise, you'll have three screws.
    • Lift the pull tab on the interposer and let it rest vertically to access all of its screws.
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the interposer.
    • If you have the graphics module, use a T5 Torx screwdriver to loosen the four captive screws securing the interposer.
  15. Expansion Bay Prereq, Remove the interposer: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Expansion Bay Prereq, Remove the interposer: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the interposer by its pull tab and remove it.
  16. Expansion Bay Prereq, Loosen the expansion bay screws: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Expansion Bay Prereq, Loosen the expansion bay screws: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to loosen the two captive screws securing the expansion bay.
    • Close the interposer door before continuing.
  17. Expansion Bay Prereq, Remove the Expansion Bay module: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the Expansion Bay module: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Expansion Bay Prereq, Remove the Expansion Bay module: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the Expansion Bay module out of the laptop and remove it.
    • The module should slide out easily. If you feel any resistance, check if the screws holding it in place are fully loosened.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
214.183 crwdns2915208:0crwdne2915208:0
crwdns2935297:01.041crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023.758crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 36
