ExoPC Slate Battery Replacement
crwdns2869540:0crwdne2869540:0: 1,2 k
2
13
62
1 166
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:020crwdne2931287:0
One of the most common issues that plagues tablets and other mobile devices is that their battery degrades overtime. This results in the device being unable to hold a charge. In this case, replacing the battery is the best option.
    1. ExoPC Slate Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
    2. ExoPC Slate Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ExoPC Slate Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the 00 Phillips screwdriver remove the two screws in the corners.
      • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
      • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
    3. ExoPC Slate Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ExoPC Slate Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ExoPC Slate Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the tape covering the metal shield as shown in the image.
      • Remove the 12 screws using the Phillips #00 screwdriver.
      • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
    4. ExoPC Slate Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove tape from the side of the battery.
      • Disconnect the battery from the motherboard.
      • Gently remove the battery.
Aaron Moore
crwdns2935283:010/30/18crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G1, Peak Fall 2018 crwdns2935289:0UMass Dartmouth, Team S2-G1, Peak Fall 2018crwdne2935289:0
UMASSD-PEAK-F18S2G1
crwdns2936753:030crwdne2936753:0 62
crwdns2959996:0crwdne2959996:0 1,166
