Evercade EXP Directional Pad Replacement
crwdns2869540:0crwdne2869540:0: 228
2
8
50
228
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
The Directional Pad, or D-Pad is the cross-shaped button located on the left side of the faceplate. The directional pad is what allows the user to control their position on the screen and is essential for operation. If it has been damaged or otherwise needs replacement, follow this guide.
    1. Evercade EXP Directional Pad Replacement, Faceplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Evercade EXP Directional Pad Replacement, Faceplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Evercade EXP Directional Pad Replacement, Faceplate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lay the device on a flat surface, with the screen facing the sufrace.
      • Using angled tweezers, remove the six rubber screw covers from the sockets.
      • The covers are all identical, so they do not need to be stored separately from one another.
    2. Evercade EXP Directional Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Evercade EXP Directional Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Evercade EXP Directional Pad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a Phillips #00 screwdriver, remove the six 8 mm screws on the lower case.
    3. Evercade EXP Directional Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Evercade EXP Directional Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the device so the screen is facing you.
      • Four hidden retaining clips hold the pieces together even near each corner of the screen.
      • Insert a Jimmy into the seam located between the faceplate and the shell.
      • Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
      • Repeat until for each of the four clasps to fully release the faceplate from the shell.
      • Do not use excessive force when moving the Jimmy. The plastic may shear if too much force is applied horizontally, and it may snap if too much vertical force is applied.
    4. Evercade EXP Directional Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Evercade EXP Directional Pad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Evercade EXP Directional Pad Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the faceplate away from the shell carefully. The faceplate is still connected to the motherboard via a ribbon cable.
      • Flip up the locking flap securing the display ribbon cable, then use tweezers to disconnect the ribbon cable.
      • Be careful when separating the faceplate from the shell, the buttons are held in place by the connection, so they may fall out when opening the device.
    1. Evercade EXP Directional Pad Replacement, Buttons: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Evercade EXP Directional Pad Replacement, Buttons: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Evercade EXP Directional Pad Replacement, Buttons: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the four circular buttons in a diamond shape on the face plate, the two circular buttons placed next to each other, and the two small oval buttons and a circular button in a row near those in a diamond pattern.
      • Using angled tweezer, gently remove the buttons from the face plate. The buttons may fall out, so be ready to catch any that fall from the device before intended removal.
      • The buttons are held in place with the pressure of the shell and faceplate when closed. They should be removed with a nominal amount of force.
    1. Evercade EXP Directional Pad Replacement, Directional Pad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Evercade EXP Directional Pad Replacement, Directional Pad: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The directional pad is composed of two pieces, the back of the button holds the face of the button within a small square hole. The pieces are held together by friction, and do not require very much force to seperate.
      • Using tweezers, pull the face of the directional pad from its socket in the back piece until the two separate.
Michael Williams
crwdns2935283:002/03/26crwdne2935283:0
356 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-6, McMurrin Spring 2026 crwdns2935289:0Utah Tech University, Team 1-6, McMurrin Spring 2026crwdne2935289:0
UTAHTECH-MCMURRIN-S26S1G6
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 50
crwdns2959996:0crwdne2959996:0 228
