This guide walks you through removing the exhaust and dust cup filters in the Eureka SuctionSeal 2.0 Pet vacuum. Refer to this guide if you notice a bad smell coming from your vacuum or you are experiencing poor suction.
Place the device upright with the brush roller closest to you.
Pull up on the latch at the top of the dust cup.
Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
Locate the gray exhaust filter cover at the top of the vacuum's base.
Grip the two tabs in the middle of the filter cover and rotate it counter-clockwise.
Lift the cover away from the vacuum.
Grab the tab on the exhaust filter.
Lift the filter straight up from the vacuum's base.
Locate the lid at the top of the previously removed dust cup.
Lift the latch and lay the cover back.
Pull up on the tag and remove the filter.
