Over time, the vacuum’s motor can become worn down. This guide shows how to replace the motor.
Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
Pry off the Riser Visor using the plastic opening tool.
Remove the screw cap using the metal spudger.
Unscrew the 14mm PH2 Phillips head screw.
Pull the bottom cover off of the rest of the casing.
Pull the power switch all the way up and remove the dust cup.
Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
Pull the casing apart.
Desolder the pictured red and black wires.
