Some vital parts of the vacuum cleaner require you to remove the casing in order to replace them. This guide serves as a prerequisite only to the guides on how to replace those parts.
Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
Pry off the Riser Visor using the plastic opening tool.
Remove the screw cap using the metal spudger.
Unscrew the 14mm PH2 Phillips head screw.
Pull the bottom cover off of the rest of the casing.
Pull the power switch all the way up and remove the dust cup.
Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
Pull the casing apart.
