This guide serves as a prerequisite only. The steps covered in this guide are used in all the replacement guides.
Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
Pry off the Riser Visor using the plastic opening tool.
Remove the screw cap using the metal spudger.
Unscrew the 14mm PH2 Phillips head screw.
Pull the bottom cover off of the rest of the casing.
