Sometimes, the belt in the vacuum can go bad or even just come loose. In order to properly maintain your vacuum, it’s important to know how to replace the belt. This guide covers the necessary steps for a successful replacement. Make sure your vacuum is off before attempting any replacements.
Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
Pry off the Riser Visor using the plastic opening tool.
Remove the screw cap using the metal spudger.
Unscrew the 14mm PH2 Phillips head screw.
Pull the bottom cover off of the rest of the casing.
Pull the roller, motor, and belt out of the casing.
Separate the belt from both the roller and the motor.
Hello would you know what belt number this would use? I have looked everywhere. I would appreciate it
