Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement
  1. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Brush Roll: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Brush Roll: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
  7. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the belt from around the motor.
    the only thing I would suggest adding is a picture of the belt tensioner which also has to be removed to seat the belt properly.
    bryanvd - crwdns2934203:0crwdne2934203:0
    The Photos also look like 2 different vacuums as the Airspeed has yellow and a different panel. if it is the bagless 3000 series, its meant to engage the roller and easliy go from carpet to floor, which is the purpose of the big gray button. It is also a Type W belt.
    Under 'Tools' it says 'No tools required.'
    Step 2. has you Using a Phillips #2 screwdriver. A screwdriver is a tool.
    Tree Rey - crwdns2934203:0crwdne2934203:0
    And it needs a part, not just a tool. It needs a belt. What belt is it for the Zuum?
    Joe McCormick - crwdns2934203:0crwdne2934203:0
    What kind of belt for the eureka muticyclonic
    Dawn Corley - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
Celina Burchett
crwdns2935283:010/13/14crwdne2935283:0
1.122 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-2, Benson Fall 2014 crwdns2935289:0Clemson, Team 2-2, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S2G2
crwdns2935297:018crwdne2935297:0
crwdns2947412:05crwdne2947412:0
It was Too hard So went to stretch the belt then it was on
missouri river production - crwdns2934203:0crwdne2934203:0
To reassemble was not available for me so I kind of did it myself but I'm having trouble getting it back on straight
eternallight6 - crwdns2934203:0crwdne2934203:0
i have read every sticker on this vbacuum read several maintenance steps …. i mean DA remove four screws …huh.
now can someone tell me whart size belt to get from the store
Sara Leinen
sparkplugkitten@msn.com
Sara Leinen - crwdns2934203:0crwdne2934203:0
I got it used. I turned it on it worked. Then it just turned off and want come back on some please help me
nickietucker81 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 48,500
