If the accessory holder is no longer able to hold the multiple tools associated with the vacuum, this guide outlines the its replacement.
On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
Using a T15 Torx Security Screwdriver, remove the screw on each side of the indention in which the hose normally rests.
Upon removal of the two screws, the accessory holder can be removed from the vacuum body.
