If your Eufy Clean Robovac G32 Pro is not properly cleaning the baseboard of your wall, then use this guide to replace the side brush.
The side brush is designed to push inaccessible debris into the path of the G32 Pro. Bent, frayed, or otherwise damaged brushes will have difficulty pushing debris and will need to be fixed or replaced.
Before using this guide, inspect the side brush for any irregularities. Typically, bent bristles can be fixed by pulling gently until they are straightened.
Before beginning, make sure to power off the Robovac.
Make sure your device is turned off.
Flip the device upside down on a flat surface.
Using one hand to hold the device down, pull up on the brush while holding onto the bristles.
